8411 Hesitates at Center
Hi Danny,
I have a 50cc gas plane with all 8411's and one of the aileron servos hesitates or hitches a little as it passes thru center. This is with the linkage removed altogether. I'm wondering if the geartrain maybe needs to be rebuilt or....? Any advice or opinions appreciated.
RE: 8411 Hesitates at Center
That could be a problem with the gear train. I would start there and see if there is a problem with the gear train. If not, I would recommend sending the servo in for a check up.
