JR Radio & Spektrum Radios Discuss all your JR and Spektrum gear.
X-347 Lithium change
Old 10-04-2005, 01:13 PM
iflidou
My Feedback: (111)
iflidou's Avatar
Default X-347 Lithium change
Danny:
I have 2 347's. One needed to have two broken switches replaced and the lithium changed. Before I replaced the swtiches I bought and soldered in a lithium. I can solder ...but also used my other 347 to check out my work. No bridges or cold connections.
Now powering up the system I get a screen that comes up with two small hour-minute (xx:x.x) displays, a smaller one on the left and larger on the right such as xx:x.x XX:X.X . Both sets of asterisks or x's are within circles with writing such as "reverse sw", "exp" , "mix" , "off-set" etc appear around the left-hand set of symbols. No beeps during any of this
I assume that what needs to be done is a reset of the processor. Please advise how this can be done. If you would like to reply directly you can send your reply to [email protected].
I would rather not have to send this into Horizon for such a small matter now that I have completed the major work.
Thanks.
Dan
Iflidou(?)
Old 10-05-2005, 08:45 AM
dsnyder
dsnyder's Avatar
Default RE: X-347 Lithium change
I'm sorry to say that I can not provide information on reseting the system. It requires proprietary knowledge of the system which we do not release. You will need to send the system in. If you have any further questions feel free to contact our product support department at 877-504-0233.
Old 10-05-2005, 08:32 PM
captinjohn
Dan: I have a X347 that needs a new backup battery. How much will this cost. Thanks capt,n
Old 10-06-2005, 08:56 AM
dsnyder
dsnyder's Avatar
Generally a lithium battery change is around $40 to $50 total. It can vary somewhat though based on what needs to be done to the system.
