Right stick causes ailerons to move irradically
GA
PLEASE HELP!
I have the Heli version of the JR 8103. I am using the R700 and 811 servos.
When I move the right stick for ailerons slowly everythings operates as it should. However, when I move them fast (without letting go of stick) the servos move beyond neutral when they are supposed to return to center. As I said I am not letting go of the sticks and letting it 'bounce'. I have tried everything...other servos...moving from a y-harness on a single channel to mixing 2 channels and I still get the same problems...that is why I think it is the transmitter.
Any suggestions? Can I send this to an authorized shop to have it re-done?
Thanks for any help that you can give.
Brent
Brent
RE: Right stick causes ailerons to move irradically
Are you sure you are not moving the stick past center? Are the servos jittering when this happens at all?
You can send the system in for a check up if you'd like.
http://www.jrradios.com/ServiceCenter/Default.aspx
GA
I had a few others ask me that too...I'm not moving them past center at all...this is just a really wierd situation. I have been flying for nearly 20 years and have never seen this happen before. Oh well...thanks for the link. I will send it in to have an expert look at it.
Regards,
Brent
Regards,
Brent
Reverse the direction of the servo at the Transmitter and see if it does the same...but to the left instead of right movement.[:-]
I have seen one time in a foamy where the aileron servo would trim differently when the stick was moved from the left than it would from the right when returning to center. In that case, the receiver was damaged from multiple "incidents" , a new receiver solved that problem. That is the only time I have seen anything like that.
