PCM 10
RE: PCM 10
Which one ? There is the PCM10, 10S, 10SX, 10SXII, 10X all in Heli or Aero versions. If you have the NET code that will pinpoint it exactly.
RE: PCM 10
Okay, just to confirm that it is the ORIGINAL PCM10 with an NET code of A110HZ, ZPCM system ? Silver back panel , DSC connector on right side above the charge connector ?
If thats the one, let me have your email address and I will send you a pdf copy. File size is 7MB unfortunately.
RE: PCM 10
We can also mail you a copy if you send your name and mailing address to "[email protected]" and request that manual. Be sure to include as much information as possible on the system so the proper manual can be sent.
