JR Radio & Spektrum Radios Discuss all your JR and Spektrum gear.
JR 9X II Programming
Old 08-24-2006, 01:49 AM
RCM IRAQ
RCM IRAQ's Avatar
Default JR 9X II Programming
Hi Danny,
I want to know how to make flaperon/spoileron set-up to my radio
would you put it in steps that every body can follow
good to be for 3D then nornal flying
Regards
Old 08-24-2006, 01:39 PM
dsnyder
dsnyder's Avatar
Default RE: JR 9X II Programming
The answer to that depends on what you are wanting to do. First set up flaperon in the wing type. Then you can use the elevator to flap menu to set up flaperon/spoiler movement with the elevators, or you can assign the flaps to SYS in device select and use the flap system to set the movement desired with a switch. There are several methods you can use, all of which are personal preference.
Old 08-26-2006, 03:33 AM
RCM IRAQ
RCM IRAQ's Avatar
Hi Danny,
you said ( There are several methods you can use,)
could you mention some short out lines for these methods just to make me find my way, how to start programming
Old 08-28-2006, 09:10 AM
dsnyder
dsnyder's Avatar
Do you want flaps/spoilers mixed in with elevator (pretty common w/ many 3D pilots), or do you want the flaps/spoilers just to move when you flip a switch?
Old 08-29-2006, 01:28 AM
RCM IRAQ
RCM IRAQ's Avatar
I like the first one
thanks
Old 08-29-2006, 08:49 AM
dsnyder
dsnyder's Avatar
For that, you can use the built in elevator to flap mix (assuming it is the same as the US 9303 system) and select a switch and enter the rate desired.
Old 11-08-2006, 03:15 PM
dxb90
dxb90's Avatar
I have a 9x 2 ... and just got an electric plane ... my 9x2 has a 72 mhz module .. and most of my planes are on band 19 .. no. 52 ....
the new electric plane i got .. i could only a crystal written on it ... CH 25 .. ((72.290)) ... which band should i be on to be able to actually control this plane .. i tired putting all sorts of numbers on my pcm bs could not get the same frequecy to the plane ???
Old 11-09-2006, 09:20 AM
dsnyder
dsnyder's Avatar
The channel numbers will need to match in order to work. I'd suggest contacting your local JR distributor for assistance, which should be Hobby Centre, the number I have listed for them is 971-4-2955512.
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
