dual servo setup for split elevator / jr 2610
Location: Gold CoastQueensland (Gold Coast Australia), AUSTRALIA
I'm after some help trying to setup split elevator servo programing on my JR 2610. Yes i have been reading the manual but seem to be ending up in the same spot, up **** creak so to speak. I have been trying to set the slave as the gear function if that makes sense so it seems clear to me that its not correct, can some one assist me in correcting this problem it would be greatly appreciated.
jason
jason
RE: dual servo setup for split elevator / jr 2610
Assuming it sets up like the US 6102 system, you'll need to set up an elevator to gear mix in mix number 4, and set the rates to +100%. Then go to the switch select function and inhibit the gear.
Thanks Danny, So does that mean I dont mix anything in mix 1 and only use mix 4? I understand that the second servo will then be placed in the gear port of the receiver, and can you still set the trim and reverse that servo if need be?
Once again thanks for your help.
Regards
Jason
Regards
Jason
