JR Radio & Spektrum Radios Discuss all your JR and Spektrum gear.
Jr pcm9x
Old 11-12-2006, 08:32 PM
AussiePilot
Default Jr pcm9x
Hey guys, im having alittle bit of trouble running my smoke system how do i mix my smoke system into the throttle stick, so basically when i use my throttle stick the pump will increase and decrease by just moving the stick movements./?? i totally have no idea and not sure which Aux channel on the reciever to put the pump into..
Thanks heaps
Old 11-13-2006, 09:52 AM
dsnyder
dsnyder's Avatar
Default RE: Jr pcm9x
You can use any aux channel that is open. To set it up, set up a program mix, mixing throttle to the aux channel that you select, select a switch to use if , and set the rates as needed to make the pump work.
Old 11-14-2006, 12:55 AM
AussiePilot
okay oh like that ok cool thanks what is the
_Norm Mast
# orig mast
What do these mean??
also just a matter of interest while im mixing the 2 channels to one switch is there anyway i can mox 3 channels too one switch?? while i was doing the smoke system i was plaing with it...would be good if i coul mix a flat spin in there only using the rudder hehe
Old 11-14-2006, 09:30 AM
dsnyder
dsnyder's Avatar
A normal mix is just that, the slave channel will follow the master, however the master channels trim if it has one will have no effect on the slave. # Orig stands for Origin mix, this type of mix uses the origin of the master channel to control the slave, that could be the aileron gimbal, aux 1 slider, etc.
