7202 and gyro sensitivity settings
OR
Danny, I have the JR 7202 and am using a 401 gyro. Do I use the gear (channel 5) ATV for setting the gyro in combination with the gyro sensitivity settings or do I set the gear ATV to 0% or ????. I am wanting to use the manual gyro sensitivity mode as I don't yet use the flight mode 1 or 2 switches. Thanks...........
RE: 7202 and gyro sensitivity settings
You can either use the gear or the aux 2 channels to set the gain, which you can either use the gyro sens function by selecting GYRO in the input select function on one of the 2 channels, or using travel adjust and using the switch assigned to that channel to set the gain.
