JR Radio & Spektrum Radios Discuss all your JR and Spektrum gear.
How to change mode 1 to mode 2 for x2720 tx
Old 04-04-2007, 02:21 AM
nowinkk
nowinkk's Avatar
Default How to change mode 1 to mode 2 for x2720 tx
Hi Danny and all,
I need to change my newly purchased JR X2720 transmitter from mode 1 to mode 2.
My problem here is: besides interchanging the stick mechanism between the throttle and elevator, is there any wiring termination that need to be interchanged as well, and how to go about it in detail?
What about the system setup? Is there any system setup that need to be altered also and how to do it?
The user manual was printed in Japanese. Can we get any English version online?
Any input will be appreciated.
Thanks.
Old 04-04-2007, 02:52 AM
alan0899
Default RE: How to change mode 1 to mode 2 for x2720 tx
G'day Mate,
Look here, http://modelflight.com.au/manuals_jr.htm
Old 04-04-2007, 03:43 AM
nowinkk
nowinkk's Avatar
ORIGINAL: alan0899
G'day Mate,
Thank you alan0899, but that manual was for XP7202 instead of my X2720. Btw, is there much difference between the two?
Old 04-04-2007, 04:02 AM
alan0899
G'day Mate,
It's the same radio, in Australia we call em X2720, in USA, they call em X7202.
Exactly the same radio, it's just how the name works, In Aus, we put modes first, 2, then channel, 7, then memory, 20.
The Yanks use channels first, 7, then memory, 20, then mode, 2.
By the way, mode refers to type of aircraft, Eg, Planes, or Heli's. Not Stick modes,1,2,3or4.
And the X2720 is the first one on the list.
Old 04-04-2007, 04:11 AM
nowinkk
nowinkk's Avatar
Thanks again alan0899.
My main problem now is how to change the stick mode from mode 1 to mode 2. I need my tx to have its throttle stick on the LHS and the elevator stick on the RHS. Please help.
ORIGINAL: alan0899
G'day Mate,
Old 04-04-2007, 08:35 AM
dsnyder
dsnyder's Avatar
You will need to contact your local JR service facility for assistance with that. For US systems they must be sent in for conversion, but it could be different for overseas systems.
Old 04-04-2007, 10:50 AM
Mac_Man_UK
Mac_Man_UK's Avatar
http://www.macgregor.co.uk/radio/doc...um%20Sheet.pdf
The standard 2720 export variant is capable of user stick mode change.
Old 04-04-2007, 09:32 PM
nowinkk
nowinkk's Avatar
Thank you Mac Man UK.
There is no stick mode change in the system of the transmitter JR X2720 that I am having problem with now. Had it got such selection in the system mode, I would not have brought up this issue here.
I hope Danny could offer some help instead of asking me to send the tx back to the dealer or worse, the JR service facility which I doubt there is any in my country.
Good Day, guys.
ORIGINAL: Mac_Man_UK
Old 04-05-2007, 03:24 AM
Mac_Man_UK
Mac_Man_UK's Avatar
If Stick Mode is not listed in the System Menu, then there is absolutely nothing that can be done. The 2720 / 7202 no longer uses jumpers to set options and this is now all in the loaded firmware, so to convert from Mode 1 to Mode 2 & vice versa, it would need a complete load of new firmware.
The only thing you can do is contact your local dealer where you got it from to see if they are willing to exchange it for the correct stick mode.
Old 04-05-2007, 03:36 AM
nowinkk
nowinkk's Avatar
It has been two days since I reported this stick mode problem to my local dealer and he is still awaiting reply from JR. I really hope the stick mode problem can be resolved soon, otherwise this radio would not be able to handle heli setting even after the alteration of stick mechanism.
Old 04-06-2007, 07:17 PM
nowinkk
nowinkk's Avatar
The local hobby shop from whom I bought this radio told me that he did not bring in any mode 2 ones, so exchanging is out of the question.
I was told also that convertion from mode 1 to mode 2 was not recommended as it involved re-soldering. I am confused now. Is it firmware or re-soldering to complete the whole convertion besides the exchanging of stick position for throttle and elevator?
Old 04-07-2007, 03:22 AM
Mac_Man_UK
Mac_Man_UK's Avatar
To do a conversion properly it needs a firmware reload. If he is talking about resoldering then it is a bodge job.
Old 04-07-2007, 08:21 AM
nowinkk
nowinkk's Avatar
In that case, I should insist on firmware reload, but is JR willing to provide that kind of firmware reload for me?
Old 04-07-2007, 06:34 PM
Mac_Man_UK
Mac_Man_UK's Avatar
Good question, you would need to ask JR and probably have to pay to ship the 2720 there and back. Is it really worth the cost ? See if you can sell it on and buy the Mode 2 version, thats probably the cheapest option.
Do you have an authorised repair agancy for your area ? It will usually be the authorised importer for the region. As they sell only Mode 1 or Mode 2 sets, then I would imagine that they will have the necessary equipment to carry out a reload.
Old 04-08-2007, 10:11 PM
CT4
If it is the same as the DX6 and the mode change does not show in the system menu then you will need to solder a resistor across the R41 blank space on the circuit board, press the reset button just below this and the mode change will then show in the system menu.
http://www.runryder.com/helicopter/t238480p1/
I did this to mine and it all works fine no software upgrade, just needed to swap the ratchet and spring.
Old 04-09-2007, 05:42 AM
nowinkk
nowinkk's Avatar
ORIGINAL: CT4
I have no idea if they are the same, and neither do I dare to try by error...
Well, re-soldering was done but the screen display does not reflect the actual surface control...sigh.
Old 10-06-2009, 06:11 AM
russzero
russzero's Avatar
hi. a old post i know. has anyone got more info about the stick mode? ive still got my x2610 (uk model) and its fab .. but just fancied the newer x2720 trannie. why spend the cash on xtals when u could spend it on servos. my mode is single LEFT stick, i believe its MODE2 reverse. ?? the x2610 has a menu ( not shown in the PDF manual) .. called simply "stick mode". from here u can alter the config into any of the 4 modes ... change the ratchet .. and go and fly. its great.
??? any idea if the x2720 has a hidden menu NOT written in the manual ??
thanks .. hope ive not repeated this post. ive been content not to need any help since my purchase of this radio.
russ uk. london
Old 10-06-2009, 07:37 PM
slarty
The 2720 sold here in the UK does support user Stick Mode change.
