JR Radio & Spektrum Radios Discuss all your JR and Spektrum gear.
spectrumdx-7 with futuba 601 gyro??
Old 05-20-2007, 02:37 AM
1david
Default spectrumdx-7 with futuba 601 gyro??
hello, i have a spectum-7 radio for a raptor se90 my question is where do i plug in the 601 gyro from futuba does it go into the rudd channel and if it does where do i plug in the servo for the collective.does it go in the last channel aux because when i do plug it in there it doesnt seem to work unless i plug it into the rudd channel does the last channel have to be programmed for that servo???? the servos are94758Z thanx...
Old 05-21-2007, 09:21 AM
dsnyder
dsnyder's Avatar
Default RE: spectrumdx-7 with futuba 601 gyro??
One lead will need to go into the rudder channel, and then the gain lead into the gear or aux 2 channel (whichever you've assigned the gear to in the input select function) and set the gain up as needed.
