JR PCM9X program
Hi, I have flap sys enabled on new jet. 2 elevator servos, one slaved on Aux3.
Flap switch enables 5% down on elevator with flaps selected. Elevator servo is OK but the servo on aux three has no response..... All else is OK, just the down mix with flaps.
I had a similar setup with the P47 that worked OK but can't remember how I achieved it!
Any one like to help smarten up an old fella please?
My Feedback: (66)
Elevators
Plug one side of the elevator into the ELEV channel and the other side into the AUX. 3 channel. Go into the System menu and choose Wing TYPE. Jog over to the Mate line under ELEV and push the roller button. A box will appear with 4 choices: GEAR, AUX2, FLAP & AUX3, choose AUX3. You have just mated the AUX3 channel with the Elevator channel; the radio will now refer to these channels as REL (right elev.) and LEL
Thank you.
The manual I have is the old original and I couldn't figure out what it was telling me, your explanation has made it easy.
