JR Radio & Spektrum Radios Discuss all your JR and Spektrum gear.
Flaperon slow down on 10X
Old 06-26-2007, 08:13 AM
ozzieflyer
Default Flaperon slow down on 10X
Hi Danny,
is it possible to set the flapperon deployment on a 10X, using the 3 postiton switch, so that the flapperons (spoilers) deploy slowly, along with the elevator mixing?
I am using 2 servos for ailerons.
I use the spoilers on my patternship, and it would be nice to hit the switch, and have the spoilers deply over say 5 seconds, along with the relevent elevator mixing compensation.
Thanks for replies.
Old 06-26-2007, 08:49 AM
dsnyder
dsnyder's Avatar
Default RE: Flaperon slow down on 10X
The 10X doesn't have a built in function to set that up without slowing the aileron movement also. You could set up curve mixes to slow down the response (mix the channel to itself, like flap to flap and elevator to elevator), assign to the flight mode desired, and set the curve up to slowly deploy, but there are only 3 curve mixes, so you wouldn't get 3 positions for both the flap and the elevator with the switch.
Old 06-28-2007, 06:50 AM
ozzieflyer
Thanks Danny,
I'll give the mix ago, as I can just use one switch setting.
