Century VII xmtr
Century VII xmtr
I am still using my CenturyVII purchased in '83. Got another a few years ago. Got another over the weekend at a garage sale for ten bucks. Not beat up, no broken switches but battery has been cut out and I can't find the ends to add a connector so no power.
I may tell you more than you need to know but here goes. * Transmitter has Las Vegas address for Circus printed onthe front panel. *Module has Reno address on it. * Freq. stcker on module says 72.960mhz. * Crystal mounted in module is labeled 72.550mhz * Module model is NET-J72M. * No "FM" printed in center of module label. * No gold sticker.
No problem resolving the power problem but what do I have here and can it be made operable as far as FM operation is concerned?
Thanks in advance for your help.
RE: Century VII xmtr
You could install a new module, you can also send the system in for a check up to be sure there are no problems with the system, which would likely be a very good idea.
