JR Radio & Spektrum Radios Discuss all your JR and Spektrum gear.
What is Z modulation for JR 9303
Old 11-21-2007, 06:42 PM
fastplane
Default What is Z modulation for JR 9303
What is Z modulation for the JR 9303 TX? What does it do? Is that something like PPM and PCM?
Thanks.
Old 11-21-2007, 07:01 PM
jonlowe
My Feedback: (12)
Default RE: What is Z modulation for JR 9303
That is the original JR PCM modulation. 512 vs. 1024 of S PCM.
ORIGINAL: fastplane
Thanks.
Old 11-21-2007, 07:06 PM
fastplane
Thanks for the reply. Having the original instead of the 1024 is that good or bad?
Old 11-21-2007, 07:18 PM
jonlowe
My Feedback: (12)
Its only for backward compatibility with old JR Z PCM receivers. Can't even buy them anymore. S PCM is more precise.
Jon
Old 11-21-2007, 07:31 PM
fastplane
OK. Thanks. I had sent TX back for small repair and check up and it came back saying they loaded latest firmware and enabled Z modulation.
However, when I turn the TX on for modulation it shows choice of PPM and SPCM.
I guess as you say then, it would be compatible with older receivers if I had one. I only have newer ones.
Old 11-21-2007, 07:42 PM
onewasp
That update (back date??) was added after the XP9303 first came out. If memory serves me correctly it WAS a part of the European version but not in the US version.
There were gripes about the difference so Horizon offered the Update which really is a back date which really was unnecessary for most users.[X(][]
Old 11-22-2007, 04:57 AM
Mac_Man_UK
Mac_Man_UK's Avatar
For some reason ZPCM transmitters had the ability to set the delay time before Failsafe kicked in. When JR introduced SPCM they removed this feature and went for a fixed delay time.
There are still a lot of ZPCM receivers out there still in use and working very well.
