JR Radio & Spektrum Radios Discuss all your JR and Spektrum gear.
DX6
Old 11-25-2007, 04:06 AM
ernest2
Default DX6
hi! is it possible to rotate the throttle / rudder stick 90 degres?so that the throttle stick will now work sideways. i will be using the radio for the tamiya f350 so its better if the ratchet type stick works for the gear shift while the rudder will control the esc.
thanks
Old 11-26-2007, 10:25 AM
dsnyder
dsnyder's Avatar
Default RE: DX6
I'm sorry to say that is not possible. You can use the gimbals in the way you describe by plugging the channels in the way you like, however there isn't a way to rotate the gimbal, nor is there a way to set up a ratchet up on the 'rudder' stick.
