DX7 EFL Paunee
DX7 EFL Paunee
Settimng up a DX7 and R6200 for EFL Piper Pawnee Using 2 servos for Eleron and two servos for flaps with a y connector.
What is the set up please for the DX7 please
BillPTC
BillPTC
RE: DX7 EFL Paunee
Ch. 1 Throttle Ch. 5 Left Aileron (Listed as Gear Channel on Receiver)
Ch. 2 Right Aileron Ch. 6 Right Flap (Listed as Aux 1 on Receiver)
Ch. 3 Elevator
Ch. 4 Rudder
System Set-Up Mode
To begin setting up the transmitter, press and hold the down and select keys, and turn the DX7 on, then release the down and select keys.
Model Selection
Press the up or down key until Model Select is on the top of the screen, and select the model you want the ultra stick on by pressing the increase or decrease key.
Model Reset
Press the up key and scroll through the menu options until you get to Model Reset. With the arrow pointing at data reset, press the clear key.
Model Type Selection
Press the down key until you get to the Type Select function. Press the increase or decrease button until the arrow points at ACRO. If you change this from heli, it will then request you to press the clear key to say yes to change the model type.
Input Select Set Up
Press the up key until you get to the Input Select function. Press the select key until the arrow points at Flap. This should say SYSTEM, if it says something else, press the increase key until this says SYSTEM. Press the select key, and the arrow should now point at flap trim. Press the increase key to set this to INH
This completes the system set up mode, press the down and select keys to exit the system mode. Do not activate flaperon in the wing type menu for this set up. All settings in the wing type menu will remain at the default setting of OFF.
Function Mode
Next we will set up the function mode of transmitter. Press the up and select keys together to enter the function list. After completing each step below, press the up and select keys to get back to the function list. To enter a function below from the list on the system, press the down and select keys together with the arrow pointing at that function.
Dual Aileron Set Up
To set up the dual ailerons, we will set up a program mix. We will use program mix 5 for this purpose. Enter program mix 5. Press the increase key until the first channel says AILE. Then press the select key to make the arrow point at the second channel, then press the increase key until the second channel says GEAR. Press the select key to make the arrow point at RATE, then hold left aileron and press the increase key until the percentage says +100%. Then hold right aileron and press the increase key until the second percentage says +100% as well. Both values should say +100%. Next to SW on the screen it should say ON. If it says something other than ON, press the select key to make the arrow point at SW, and press the increase key until it says ON.
Flap System
Enter the FLAP SYS function. Use this to set up the flap movement as required.
Ch. 3 Elevator
Ch. 4 Rudder
System Set-Up Mode
Model Selection
Model Reset
Input Select Set Up
Function Mode
Dual Aileron Set Up
Flap System
