X9303 Range Testing Question
CO
Danny - Just got a new X9303 and just got back from using it. It worked great except one question on the range test. I was flying a small electric with the AR6100 Rx. I stood 30 paces away from the model, depressed the bind button and had total control except for when the antenna of the Tx was pointed directly at the model. I flew twice after that and had no issues. Is this normal?
Thanks!
Thanks!
Location: Bishop\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'s Stortford,
RE: X9303 Range Testing Question
The signal is the weakest when pointing at the model and since you were at the extremity of the range test I would have been happy to fly.
Hope this helps
Hope this helps
