X9303 Aileron Travel Variance...
My Feedback: (16)
TX
I've run into a puzzling issue that I can't seem to resolve...
I have the typical 2 channel aileron setup... Wing Type set to "Flaperon", right ailerons plugged into channel 2 and left ailerons plugged into Aux1... I have Travel set to +/- 145 on both channels... On the right ailerons, I am get 60 degrees of travel... On the left ailerons, I am only getting 40 degrees of travel...
All servos are Hitec 5955TG's and the centerpoints & travel were set with a programmer...
Thinking that something may be amiss with the internal Flaperon mix, I set wing type to "Normal"... Then setup a programmable mix from AIL to AUX[1-4], matching travel... Same result... Only getting around 40% of travel on the left ailerons...
Anyone run into this or know of the fix???
RE: X9303 Aileron Travel Variance...
When you choose flaperon you should be able to set the travel volume independently on each channel
That's the purpose of flaperon so you can set more up than down travel to compensate for yaw in a rolling maneuver
My Feedback: (198)
ORIGINAL: Torqued-Up
That's aileron differential you're referring to, which is set independently from travel...
My Feedback: (16)
TX
Thanks for the reply...
I've already setup a new model in memory and started from scratch on the programming... Same result...
All switches are set to INH in the model setup...
The issue is that I am getting +/- 145 travel on the right aileron, but no matter what the setup is in the radio, I'm only getting +/- 100 on the left ailerons... To get the travel to match, I have to set the right aileron travel to +87 & -73... Mechanically both sides are identical...
Also, this is off topic, but but has anyone else noticed a radical change in your throttle trims when you setup a programmable mix??? This has happened more than once... I'll setup an airplane with no mixes... Then as I tune the airframe, I'll add a rud-ail or rd-elev mix... As soon as I enable the mix, my throttle trims are way, way off...
What is happening on the servo monitor? Are they moving the same there? If so, it is something in the model/servos. If not, it is in the programming. Make sure you have centered the servos properly (either inhibit the flap in device select or make sure you are in the true center position on the servo monitor before centering the servos.)
