JR Radio & Spektrum Radios Discuss all your JR and Spektrum gear.
AR9100 : 3 questions
Old 02-20-2008, 06:36 AM
freddd
Default AR9100 : 3 questions
1) The documentation says minimum voltage of 6V. Is the following an acceptable solution : 2 Lipos with a good quality regulator (Emcotec, Fromeco) at 5.5V. This would still maintain a margin to the minimum 3.5V
2) Battery management. If you use 2 batteries, are these used at the same time or is there a switching from one to the other according to voltage drop.
3) Can you use the AR9100 without the switch. This is in the case where the regulator already has an electronic (fail-on) switch.
Thank you
Old 02-20-2008, 09:18 AM
dsnyder
dsnyder's Avatar
Default RE: AR9100 : 3 questions
1) That is fine.
2) If one pack voltage is higher than the other, the higher pack will be used. If they are the same voltage they will be used equally.
3) Yes you can. It is best not to install a switch between the batteries and receiver (as that is the idea of the soft switch, to eliminate a potential failure point and increase current draw capabilities of the system), but if it is a soft switch on the regulator that will be fine.
Old 02-20-2008, 04:54 PM
freddd
Thank you.
Old 02-24-2008, 12:33 PM
CH3CH2OH
Can I charge my a123s while plugged into the ar9100 or do they have to be disconnected?
Old 02-25-2008, 09:32 AM
dsnyder
dsnyder's Avatar
You can charge while plugged into the receiver, however the receiver will draw a small amount of current at all times while the batteries are plugged in, so disconnect them if you are not flying for a few days.
Old 02-25-2008, 09:41 AM
CH3CH2OH
