JR Radio & Spektrum Radios Discuss all your JR and Spektrum gear.
9303 Delta Elevon Setup Hassle
Old 06-08-2009, 08:53 PM
1Eye
1Eye's Avatar
Default 9303 Delta Elevon Setup Hassle
OK, I've got a 9303 and I go directly to page A13 in the manual to set up the elevons on my Rookie II jet. The left and right wing elevon servos are plugged into the correct ports (ELEV and AILE, respectively) on the AR9000 receiver. I'm thinking this is a piece of cake... wrong.
I had to reverse *both* the L and R elevons to obtain correct surface deflection for pitch control - but then, of course, the ailerons are now reversed from what they should be for correct roll control. I cannot for the life of me figure out how to get the correct deflection for roll. Dohhhh. What in the heck did Imiss? Is there some other mix I need to program? Any clues would be appreciated.
Mike
Old 06-08-2009, 08:59 PM
V2PLUS10
Default RE: 9303 Delta Elevon Setup Hassle
Try swapping the receiver ports, and then you will probably have to reverse one or both servos....
Old 06-08-2009, 09:32 PM
1Eye
1Eye's Avatar
Cool beans . . . that worked- thanks! Imust've mixed up the channels. Now off to set the rates/deflection for pitch and roll.
Old 06-08-2009, 09:48 PM
V2PLUS10
Glad that worked!! That elevon mixing can make you crazy....!!
Old 06-09-2009, 05:54 PM
junglejet
junglejet's Avatar
you didnt mix up the outputs......JR thought all control horns were under the control surfaces
