help needed with jr10x
IN
help needed for jr10x .when you turn on transmitter the touch panel display has black line through it and then it goes blank .
screen does not come on.No signal to plane.It makes sounds when you move trim tabs.
RE: help needed with jr10x
Before you send it back, make certain that you haven't accidentally set the contrast all the way down. I have had a couple sent in for "repair" only to find nothing wrong with it except for the contrast set low.
