JR Radio & Spektrum Radios Discuss all your JR and Spektrum gear.
xp642
Old 07-01-2003, 08:57 PM
k-harr26
Default xp642
Danny,
I have an xp642 that i am having problems with the throttle. The throttle does not respond until the stick is centered to forward. the trim slide does not respond either. In sub trim the persentage is 0% until the stick is centered then goes to 100% from that point forward. Can you give any help on this I think I have programmed this problem in or is the poteniometer in the stick bad?
Thanks Kurtis [email protected]
Old 07-02-2003, 02:32 AM
bearmech
Default xp642
Is it in the heli mode?
Old 07-02-2003, 12:18 PM
dsnyder
dsnyder's Avatar
Default xp642
It sounds like you have set the throttle travel adjust to 0%. In sub trim there is only one percentage which adjusts the center position of the servo. In travel adjust however, you can set the high and low throttle end points, and as you move the throttle stick the percentage will move from low throttle end point to the high throttle end point. With the stick at low throttle, set the travel adjust percentage back as close as you can get to 100%, and still have proper throttle movement.
