JR Radio & Spektrum Radios Discuss all your JR and Spektrum gear.
Power Output
Old 10-17-2009, 05:09 AM
RonP
Default Power Output
I was just looking through the manual supplied with my JR 9xII transmitter and noticed the specified RF output was 750mW - the limit in the UK is as far as I know 100mW. I have 2 transmitters and both the manuals specify the same output.
The transmitters have MacGregor stickers fitted but not serial numbers. (my old PCM9x had stickers and a valid serial number). Could they be grey imports or are the manuals wrong?
Ron
Old 10-17-2009, 05:56 AM
slarty
Default RE: Power Output
Hi, ignore the manual as it is written in the US.
The power limit in the EU is 100mW EIRP but in reality (due to the inefficiency of the antenna system) you will be transmitting less than that.
Serial numbers SHOULD be in the battery compartment.
Old 10-17-2009, 06:10 AM
RonP
Ok - cheers.
No serial number in either tx though!!!
Ron
Old 10-17-2009, 06:16 AM
slarty
Hi Ron,
That is weird.... where they new when you bought them ? Also, whicj shop did you get them from ?
Old 10-17-2009, 06:30 AM
RonP
Mmm - they were S/H from BMFA.
I have an RF power meter - I will try and do an RF power measurement. I will need to connect to the antenna stud somehow. I will post the results.
Ron
Old 10-17-2009, 06:43 AM
slarty
Ron,
Sorry.... cancel my last... the serial numbers are in the module housing. Pop the module out and they should be on a silver label to the left of the interconnecting pins.
Old 10-17-2009, 06:48 AM
RonP
Phew - cheers slarty - both have their serial numbers as you described.
Job done.
Ron
