JR Radio & Spektrum Radios Discuss all your JR and Spektrum gear.
My R720 Synth Receiver no longer works
Old 10-18-2009, 08:40 AM
laiosto
Default My R720 Synth Receiver no longer works
I went to fly my plane today and was surprised to find that the receiver a synthesized Jr R720 wasn't working.Apart from unplugging the battery nothing different had happened to the plane since I used it last the week before. I tested the transmitter with some of my other planes with crystal receivers and had no problems with them. I have followed the manual to reset the receiver frequency but only get the slow flash of the LED which means it has't locked on.Any ideas anyone?
Old 10-18-2009, 12:56 PM
slarty
Default RE: My R720 Synth Receiver no longer works
Are you absolutely certain that you have set the correct modulation on the Transmitter for that receiver ?
If you have set PPM for a PCM receiver, it shows a slow flash sequence and the same for PCM for a PPM receiver. (Not certain what the 720 is ... I only know the standard JR naming)
Old 10-19-2009, 05:02 AM
laiosto
I checked the writing on the receiver case ,it is a R77s not a R720 and sure enough it says SPCM and the transmitter was on PPM.I changed the transmitter to SPCM and the problem is solved. In my defence ,I can categorically state that I have never changed the modulation settings on this model memory,One of my friends must have mucked around with the transmitter.Oh well,you live and learn.At least it wasn't a problem that occured while airbourne.Then I would have been truly stumped.
Old 10-19-2009, 05:03 AM
laiosto
Old 10-19-2009, 05:05 AM
laiosto
