JR Radio & Spektrum Radios Discuss all your JR and Spektrum gear.
wrapping servo wires
Old 10-20-2009, 12:08 AM
Default wrapping servo wires
On 120 yak with gas engine, x9303 2.4 radio, HS 7985 servos.
Can i wrap the two elevator servo wires into the same wire wrap from the back of plane to the rx.
Tom P
Old 10-20-2009, 06:27 AM
PacificNWSkyPilot
My Feedback: (19)
PacificNWSkyPilot's Avatar
Default RE: wrapping servo wires
Shouldn't hurt a thing. Accepted wisdom is that winding them around each other minimizes potential RF noise, you might want to throw a couple of twists in there if you've got wire length enough. Your 2.4 gHz is SO advanced compared to the 72mHz that it's virtually immune to that. But you know the definition of "virtually" is "Seems to be, could be, but in fact is not", so, it never hurts!
Jimbo
When coming toward you, rightside up or upside down, the low wing gets the stick. That's the LAW and it never changes, EVER.
Old 10-20-2009, 10:38 AM
Can not read post.
Need info! Thanks
Tom P
Old 10-21-2009, 08:20 AM
BarracudaHockey
BarracudaHockey's Avatar
Yes
Old 10-21-2009, 02:51 PM
Tom P
