JR Radio & Spektrum Radios Discuss all your JR and Spektrum gear.
347
Old 07-07-2003, 02:33 PM
cheyenne
Default 347
Hi
I was wondering if there is any way I can program a pre-set switch for a Discus Launch Glider using my 347. I have gone through the manual and can't seem to find that kind on programming.
Greg
Old 07-07-2003, 02:49 PM
dsnyder
dsnyder's Avatar
Default 347
You can set this up flaps through the land system in the 347, and if you need other functions you can mix them to the same switch. You can set up a rudder offset as well by using a program mix and assign it to the switch of your choice, where you will mix rudder to rudder and enter the percentage as needed. What exactly are you needing to set up with the switch? With little more information we can provide more assistance setting that up.
Old 07-07-2003, 03:02 PM
cheyenne
Default DLG with a 347
I am needing to program rudder and mabe a little elevator into a switch for when I launch the glider.
Old 07-07-2003, 03:04 PM
dsnyder
dsnyder's Avatar
Default 347
To do that you will need to set up a rudder to rudder mix, and an elevator to elevator mix, assign them to the same switch, and enter the percentage needed.
