parkzone micro cub won't bind
My wife and I won a parkzone micro cub (BNF) at a recent club event.
I haven't been able to make it bind to my radio however. Does anybody know of any tricks or extra steps required to get it to bind?.
I'm using a spektrum module with a futaba radio. The binding procedure is the same as the DX7 though. I've followed the same steps a dozen times now, and the cub LED keeps blinking. I've used the spektrum module with full sized receivers without a problem, so this is a mystery. I tried standing 50 ft away, turning off my wireless router, etc., to no avail. I'm wondering if there's a compatibility issue or perhaps something is defective.
Please reply if you have any ideas, suggestions, or comments. Thanks!
RE: parkzone micro cub won't bind
Yes, 99% sure that it's on PPM. I'll double check tonight. Do you know if there is a general compatibility issue with the modules and the micro BNF planes?
I checked my PPM signal going to the module and verified everything still works with a different plane. It's looking more and more like a defective cub or a module/plane compatibility issue. Any comments from HH would be appreciated.
My Feedback: (41)
ORIGINAL: hessian123
If you want to talk with Horizon, you'll need to call or e-mail 'em....
Just got off the phone with HH. This HH phone support experience was MUCH better than my last one. They agreed that if the radio/module combination worked with my other full-range Spektrum systems, then it should work with the micro cub RX as well. They're shipping me a new micro cub RX board to try. Excellent service, good job HH!
