XF622 Manual
Is there any way to get a copy of the XF622 manual? I purchased a used heli that came with this radio. I have found the manual on-line but it is hard to read.
XF622 Manual
You can send an email to [email protected] with your name and mailing address, request that manual, and we can mail you a copy.
Thanks and another question
Thanks for the manual. Now I was wondering if I could use crystals that came with a Lexor radio (Ikarus Piccolo). I purchased a kit and it came with a radio and crystals. I would like to use this radio so that I am used to using it. The kit has a Piccoboard Plus that has the futaba/JR shift setting. The set of crystals are on channel 13. If that won't work, if I get a channel 48 crystal for the piccoboard and my radio is on 48 will it work?
XF622 Manual
You need to use JR crystals in the JR system. You could send your system in and have it converted to the channel you are wanting to use it on. Or get a crystal for the piccoboard on channel 48 like you say. If the Piccoboard is made for futaba and does not have a switch to change the shift to JR, it will not work however.
Thanks for the info.
I just called and asked to exchange the channel 13 crystals for a set of channel 48 crystals. The Piccoboard supports both JR and Futaba so there shouldn't be any probelm there. There is just a jumper that needs to be moved.
P.S. Are there any upgrades that I should have done to this radio? I noticed that the model is no longer being produced. It is an XF622 Plane/Heli. |
XF622 Manual
There are no upgrades available for the 622 system. If you have any further questions please let us know.
