12X auto dual Rudder rate?
I'm trying to set up an auto dual rudder rate on the throttle. Anyone got a clue how? I sure don't.
Tim |
RE: 12X auto dual Rudder rate?
Bump
Have you tried setting up a stick position switch on the throttle stick? Then using the SPS you can either use it to trigger the extra flight mode, if you are in ACRO or use it as a select switch for a program mix to modify the rudder rate.</p> Allan</p> |
