DX9 - Removing TX Battery
I am trying to remove the DX9 TX battery so that I can change the throttle so that it has the ratchet. I have removed the cover but cannot get the battery connector to disconnect. I do not want to put too much force and break the connection on the printed circuit board.
What is the secret to disconnecting the battery? |
No there is no trick! I just carefully wiggled it out....
Thanks !!!! I guess I did not wiggle it correctly when I tried earlier... I can now change my throttle stick to the ratchet configuration.
