Setting 4 Flap Servos with a DX18 and a 20310T Receiver
Hello Guys, never used/set-up a 20 channel receiver before. I know the answer to my problem is starring me right in my face BUT I just don't see it yet. HELP I am setting up a jet. It has two split flaps/servos per wing. In my setup so far, I have one flap servo on channel 5 (left) and one servo on channel 7 (right). However, I am use to using "AUX" channels to plug the other two servos into to combine with the primary servo plugged into channel 5 and 7.
My problem is: The 20 channel receiver has no labeled "AUX" channels. Please explain how I am to 1. Connect the second of the two servos of the Left Wing into what channel that will align it with Ch 5 and 2. Then connect the second of the two servos of the Right wing into what channel that will align it with Ch 7 I'd like to thank all of you for your advice and help. Chic |
Did you set the proper wing type?
Yes, 2 Ailerons and 2 Flaps
Look at the Monitor screen.
The channels start at 1 for Throttle. Then 2 = right aileron, etc. Just go from there. If you look at the Channel Assign screens, it will show both name and number if you get lost. Andy |
