Spektrum receivers
I must be doing something wrong. I can'T get the throttle channel to work on channel 3? A channel that should be default to throttle position. By using 3 for elevator. This leaves no ability to changing rates and expo. for that channel. what am I doing wrong.
spektrum receivers
What gear have you been using before? it's common for throttle to be channel 1. it doesn't hinder rates or expo on ch2 AIL, ch3ELE or ch4 rudder. if you want ch3 to be throttle you should get an Opentx system!
Futaba uses channel #3 and the travels MUST be reversed.
