Dual elevator servo mixing, Prog mix 5,6???
Plan to use two elevator servos for each elevator half. JR 945S PCM RX and 8103 transmitter.
Need extra servo to have Dual rates, expo, trim, sub-trim memory to all be slaved to elevator, and controlled by elevator functions. I have tried using program mix 5: Elev to aux 3, but don't like the fact that the +/- knob switch when rotated could affect the position of the elevator. |
RE: Dual elevator servo mixing, Prog mix 5,6???
Set up a mix using 3 or 4, mixing aux 3 to aux 3, and set the percentages to -100% with the knob is rotated in all positions, and you are set. You can find programming help here: http://horizon.hobbyshopnow.com/prod...b=support#tabs
