9303 trainer switch
Can anything be put on the trainer switch beside the timer? I would like to put engine kill on it but I cant find it listed in nay of the mixes as a switch
RE: 9303 trainer switch
noone ? so this switch is basically just a worthless switch even on the 9303?
On the model we have - PCM 9X - you can definitely use the trainer switch for throttle cut. "Thro Trim" is what is listed on my display.
Mine is 14 months old now and was a great buy. Our model unfortunately has electronic throttle trim but I am used to it now. We also only have 20 model memory. Zane |
Just give Danny time to answer.... he was away from work last week, so he will be catching up on all the questions as well as doing his normal job.
He will respond as soon as he can. [8D] |
The trainer switch can be the master "channel" in the program mixes, which allows almost any number of combinations to be used with this switch.
I finally found that last night . I have the heli version and was looking for the snap roll switch , but i see its called button actually.
