27% ultimate on 6 channels
I am looking at getting a WM 27% ultimate but I am unsure that my radio (JR 2610) will be able to cope with all the servos. I would like to use hitec digitals probably 5945's all round expect throttle. Will I be able to run the Hitec 5945's on a y lead for each wing. (top and bottom) And then setup a mix to mix the top and bottom wing together??? Will this get everything working ok?? I will be running a JR pcm receiver (9ch) so I can still plug in my voltspy.
RE: 27% ultimate on 6 channels
Yes, it should work fine. Use the flaperon function to set up the ailerons.
Cool thanks.
