Spektrum
Danny,
I am really enjoying the DX6. However I like rather strong stick tension. I believe the DX6 is based on a JR radio. How can I increase the stick tension? Thanks for your help. |
RE: Spektrum
To increase the spring tension will require changing the springs. I would recommend sending it in for this conversion.
RE: Spektrum
Danny,
Thanks for the prompt reply. In general I like the Sektrum system, so I think I will use it as is and wait for your hopefully soon to be released upgraded radio. The features I miss most are: 1.) Real dual rates and Expo on the rudder 2.) Adjustable spring rates 3.) Timers with alarms for each model 4.) Single step trim adjustments 5.) Longer model names Which are also displayed during model selection |
RE: Spektrum
Can anyone tell me how to properly set-up the Delta Wing mix on the DX-6,,,, for some reason when I do it as the directions tell me,,, I always have one of the pair of ailerons or elevators in opposite direction. Reversing the servo's doesn't cure it, always just makes the other reversed then,,,keep chasing it around. And the directions are sure vague in how to set it up. When I hook the servo's the opposite way they say,, I can get it to work the proper direction, but never can get both to work equally.... been fighting this forever...
RE: Spektrum
Get your ailerons working properly with servo reversing. Then if the elevator makes the surfaces move the wrong direction, swap channels that the servos are plugged into in the receiver.
