9303 & Elevator -> Spoileron mixing
Hello again,
Well, I'd appreciate your input on mixing spoileron to elevator. I'm sure the answer is under my nose, but I haven't figured it out. I tried enabling the flaps to start from that direction but that got me nowhere. So, I'm attacking it from the mixes...any links to an article or other resource would be appreciated. Thanks for your help Danny. Robert. |
RE: 9303 & Elevator -> Spoileron mixing
What a knucklehead...I figured it out!
Couldn't have been easier :eek: If you are reading this with the same question, I'll tell you what to do: LIST: select ELE -> FLP Pick a switch to assign to the job I used Aile D/R switch, position 1. You could assign it to a flight mode by choosing FM0, FM1, or FM2 I'll start with -40% DN and UP and play with it from there. I could swear I played with that mix and had some difficulty!?!? Anyway...problem solved. Happy Holidays Danny! |
