Voltage
Will my 8411's be happy at 6 volts? Or is there drawbacks to running them at 6 volts?
Voltage
8411's work fine on 6 volts. The wear on the servo may be slightly higher, but overall there are no problems caused by using a 6 volt system.
Voltage
Thank you Danny. :)
