Spectrum receiver quits-----HELP
Hi Danny,
Yesterday I bought the second AR7000 receiver to go with the DX7 I bought about a week ago. I installed it in a plane and followed the instructions about binding. Today, as I was range checking, I was rotating the right stick in a circular motion so it would activate the ail and elevator, when it just quit for about 4 or 5 seconds. It would move the surfaces for a few seconds, quit for a few, then repeat. I went thru the binding process again, but the problem stayed with it. I did notice that when the servos quit, the lights on both receivers went out. Did I do something wrong????? Should I send it back to Horizon???? Dale |
RE: Spectrum receiver quits-----HELP
After messing with the system for a little while, I isolated the problem.
THE SWITCH!!!!!!!! Apparantly, it would carry enough current to bring the system up, but not enough to operate a couple of servos too. Thank you anyway. Dale |
Well see that's 1001 things that can go wrong!
In over 45 years in this hobby, no servos then, rubber band excapements, I have seen 2 bad switches. |
Ihad the same problem.My switch has the built in charging port.It was driving me crazy trying to figure out what was wrong.
John |
