Help 7202 problem with locking up accessing model 6
I got my 7202 out today and was going to do some testing with my foamy. When I powered it up it beeped then shut down seems the battery was almost dead since I havent had it out in a while. I had accessed Model 6 before it shut down. Well charged it up and then went to pull up model 6, it would go to 5 then beep like it was going to 6 but it stayed on 5 and was locked up. Turned off and tried again from 20 down and same thing. Tried several different times and even took the battery completely out and let the radio set unpowered still no change. It hasent been used but maybe 2 hours total and most was sim. time. Any body had this problem or know what to do??
RE: Help 7202 problem with locking up accessing model 6
It sounds like the system will need to be sent in for service.
Where do I send it and what will it run for service. Its still under warranty.
All your questions should be answered here.
http://www.horizonhobby.com/Content/...rchecklist.pdf If the service techs find that it is covered under warranty there will be no charge. If it is found to not be under warranty, charges will apply. |
I too have this same exact problem. Can two people have the same random problem. I think there is an issue with the 7202 that needs to be looked into JR.
Yeah it sucks pretty much. Danny Can you send me the PDF file for the checklist in an email I cant get the link you posted to open. Email is [email protected]
Try right clicking the link and selecting save target as, then save in my documents or other location you can access. Then open the file. You will need to have adobe acrobat installed on your computer to open it. If that doesn't work, send an email to "[email protected]" for assistance.
