Which one better, between JR9303 and JR10X?
Dear all,
please advise between JR9303 and JR10X, which one better? As we know 9303 has synthesized module. Which one is better? Thanks and regards, andrew. |
RE: Which one better, between JR9303 and JR10X?
JR9303 is better you can fly everything you want to, compare to the JR10X you have to choose either plane or heli.
Hi thanks for the info.
I just confuse of your statement about, "...JR10X you have to choose either plane or heli...". Means? Is one version 10x radio just can be used for airplane or heli only? Couse some one that used 10X heli said that, he can use his radio for his airplane too. Please inform me about this. Thanks and regards, andrew. |
If you are going to buy a 10x you need choose the version that you fly most, yes you can fly plane with a heli radio but it is not the same. The 10x is a great radio but no one nowadays would choose a 10x over 9303. The 9303 has Air, Heli, Sailplane and 30 Model Memory
Hhmmm, i see.
Thank you very much for your information. Best regards, andrew. |
The 10X does have some increased programming capabilities over the 9303. Both are great systems, the choice comes down to which serves your purposes better.
Well, everybody minus 1 . . . I would definitely take a 10X over the 9303 . . . .
- Tim ORIGINAL: Wlouigene If you are going to buy a 10x you need choose the version that you fly most, yes you can fly plane with a heli radio but it is not the same. The 10x is a great radio but no one nowadays would choose a 10x over 9303. The 9303 has Air, Heli, Sailplane and 30 Model Memory |
Another 10x over 9303 here. Hands down.
OK... thanks to all of you, for the informations... 10X? Hmmm....
regards, andrew. |
I have both the JR10 and a newer JR9303. With the JR10's touch screen it is my favorite and has more user friendly programs for mixing complex scale airplanes controls.
If your game is airplanes only, Then I would have to say I like the JR 10 best. Can you find a JR 10SXll?? The JR 10X is getting to be a old transmitter...but still a good one. With the newer JR12 coming out this fall I thought I would have to get me one as I have a use for a couple more channels....but alas....no touch screen on the top of the line JR12...so I guess no new radio for me this next year. |
The 10SXII is older than the 10X - the 10X can still be purchased new, so not sure what you mean here . . .
- Tim ORIGINAL: MX240 I have both the JR10 and a newer JR9303. With the JR10's touch screen it is my favorite and has more user friendly programs for mixing complex scale airplanes controls. If your game is airplanes only, Then I would have to say I like the JR 10 best. Can you find a JR 10SXll?? The JR 10X is getting to be a old transmitter...but still a good one. With the newer JR12 coming out this fall I thought I would have to get me one as I have a use for a couple more channels....but alas....no touch screen on the top of the line JR12...so I guess no new radio for me this next year. |
I'll take the 10X over the 9303. That's 3 people so far....
The 10x is a very good radio and everyone here would testify to that, in my opinion JR has the best radio, but if you ask me to choose between the 10x and the 9303 I would take the 9303
Owning both radio's I prefer the 9303.
LISTEN YOU GUYS.
These top end radios, JR 10x and Futaba's equiviant aren't expensive for fun. The build quality is better, the component quality is better, the engineering quality both machanical and electrical are better. These bells and wistle radios are good, I've had several and I still operate one but it just can't compare to my 10X. Thats a real quality piece of kit. The moment to pick it up and feel the weight you know that this isn't toy shop engineering here and you'll instantley understand you're paying for something in a different class. Not neccessarily in features, but in over all quality. I was once informed that JR (Japan Radio) produce all of the radios overseas, as does Futaba. The 10x on the other hand is poduced in Japan, using very high spec components. I believe Futaba still does the same. The do-everything, cheaper radios are great but you only need to ask yourself why they're cheap, whats caused the price reduction, where have they cut corners, where are the saving etc... to find all the answers you need to buy the top end alternative. |
Hi bla bla,
I was once informed that JR (Japan Radio) produce all of the radios overseas, as does Futaba. The 10x on the other hand is poduced in Japan, using very high spec components. Try Google and "Japan Radio" |
Please remember that this forum is for manufacturer direct support and not for open discussion.
