X9303 ques
Quick question, I had my plane setup with a 9303 and the spektrum module and ar9000 rx. I just swapped it out for an x9303 and the 921, transferred all my numbers to the x9303. When I turned on the radio everything works fine, but all my centers were off and endpoints off a bit, what is the cause of this? Thanks
RE: X9303 ques
Centers can be different from system to system, as there are mechanical pots involved in the gimbals, and they are not identical in every system, and they can wear over time as well which can affect the center as well. It is not uncommon to have to re-trim when going from system to system.
