X9303 - 921 Receiver Question
I may not be looking at the right page in the manual. On the 921 RX, there are two ports below the 9 servo plugs. Can someone please advise what these are for.
Thanks, Vince |
RE: X9303 - 921 Receiver Question
Vince, you ask the most simple of questions. It has to be if I can maybe answer it. I've been working on setting up my planes as my X9303 and receivers arrived about a week ago. Anyway, they are just as labeled. One is for binding and the other is for the Spektrum Flight Log if you have/use one. And I'm reasonably sure you can power the receiver in either of the two batt ports or through an empty servo positon as with other receivers. By the way, what are you doing up so early?:)[8D];):D
:eek: Figures. I should have looked first. I just looked at my manual, and just like you said, right in front of me. I will get to that this week. Ready to install in new 86" Yak. I may put this new radio in another plane, trainer type, for test, etc.
Vince |
Don't feel bad. I was kinda surprised at the sparseness of the 'manual'.
