XP783 Tx dead
Pulled out my old XP783 transmitter which I haven't used in a couple of years and plugged it into a Futaba charger. Doh!
I had it plugged in for just a minute or two, but now it doesn't turn on and when I plug in the JR charger the charging lights don't come on. How bad have I fried it? Is it fixable? Any help appreciated. Dave |
RE: XP783 Tx dead
G'day Mate,
You have probably blown the fuse inside, take the back off & have a look, replace it & see if you were lucky or not. But I bet you won't do it again. |
RE: XP783 Tx dead
Just checked. The fuse is indeed blown. Will try to get another today and hope that's all the damage I did. Thanks.
RE: XP783 Tx dead
That is exactly what the fuse is there for. I doubt it is ruined. At the least, you should try replacing the fuse first, and cross your fingers. I have known of two other JR transmitters that were connected to Futaba chargers, and they were both fine after replacing the fuse.
Radio Shack has fuses that will fit your transmitter. http://tinyurl.com/2g6pfl You can also buy them from Horizon Hobby. http://www.horizonhobby.com/Products...ProdID=JRPA030 |
RE: XP783 Tx dead
A quick trip to Radio Shack and $2 worth of fuses and I'm back in the air.
Thanks to all who helped me fix my boneheaded maneuver! |
RE: XP783 Tx dead
One question. What is a JR guy doing with a Futaba charger anyway? Dennis
RE: XP783 Tx dead
I made some mistakes in my past.
