12x satellite receiver location
i'm installing a 12x system into my boomerang intro and is room tight. i want to put one of then on my kevlar fuel tank but i'm thinking it might either get a static spike or get shielded because of the kevlar. this is my first 2.4 sys and i don't want to lose my plane over something stupid,thanks for the help. WB_1
RE: 12x satellite receiver location
I recently converted my intro from 72 mhz to 2.4 and I mounted my satellites in the nose (horizontally polarized) , mid-fuselage (mounted on the side inner wall in a vertical polarized orientation and the third satellite behind the kevlar tank in a horizontal position. I actually used some gaffers tape to secure the horizontal antenna orientation so the suction from the compressor would not try to bend them in an aft or backward direction .
Hope this helps ...works for me with no problems Steve |
