9303 Dual Elevator trims
I need some help. I programmed my radio for a dual elevator set up. Right side goes to EVE channel and LEFT to AUX2. So far its mixed on MIX3.
DEVICE SELECT is: Flight Mode - AUX2 SW Trim - COM D/R - FM AUX2-AUX2SW-INH WING TYPE is: Wing - Flapperon DualMate - ELEV INH In this set up both elevators work fine but not for the trim. If I were to go to WING TYPE and set DualMate - ELE AUX2 then when I move the EVE one side moves as normal and the other wiggles a bit. What have I missed out on doing it right? Any assistance please? Thanks!!! |
RE: 9303 Dual Elevator trims
Okay ... found out that I should only mate and not MIX ...
