12x-dx6i compatible for training ?
i have a new 12x and a new dx6i . i bought the dx6i to use in my lower end airplanes and i was wondering if (1) i can use the 12x and the dx6i together with a trainer cord ? and (2) can you switch back and forth as to which transmitter is the master ? thanks for any help you can give ,WB_1
RE: 12x-dx6i compatible for training ?
Unless the 12X specifically lists restrictions as to what can be used as a Buddy Box, you should be able to connect the two radios with a Trainer Cord, turn on the Trainer program in each radio, and use the Trainer Switch on the Master to Give or Take control from the Slave.
Every radio has different quirks when it comes to the Trainer system. Some have a Trainer program and some do not. Some allow you to turn certain channels Off and On for the Buddy Box. |
And by what authority do you give this advice? hey you going to the auction today?
Yes!!
ORIGINAL: warbird_1 ..... and (2) can you switch back and forth as to which transmitter is the master ? Rafael |
