KingTech Turbines International Barry is your host and will help you with all your Kingtech questions and concerns.
K100G 3SLipo ECU BATT
Old 01-30-2013, 01:48 PM
flyloose
flyloose's Avatar
Default K100G 3SLipo ECU BATT
Hi..
Could I run a 3S lipo (thinking 3200mah) on my 100G ECU? I'm finding especially here in Canada it's hard to find a 3S LIFE style of pack. Would 11.1v nominal be too much for the ECU? It would sure make my setup easier.
Thanks, Eric
Old 01-30-2013, 04:09 PM
jws_aces
My Feedback: (33)
jws_aces's Avatar
Default RE: K100G 3SLipo ECU BATT
Eirc, I also wish we could use lipo instead. I just started my k180g and I accidently connected a lipo instead and the ECU sensed over voltage. It will not work. If they would offer a software update that would be nice but I have a feeling the internals can't handle the extra voltage.
Oh yea it is sweet!
JMO
Jeff
Old 01-30-2013, 05:29 PM
FenderBean
FenderBean's Avatar
Thats correct, 9.9 volt LiFe4 pack is a good pack and with a fully charge pack you still may get the occasional over voltage. I just bump the starter for a couple of seconds before I even go trim up.
Old 01-30-2013, 06:27 PM
marquisvns
marquisvns's Avatar
3S LiPo has a nominal voltage of 11.1 and will peak at 12.6V, which is way to high for our system, make sure you follow instructions in the manual and stay with 9.9 LiFe or 8.4 NiMh, thank you.
Barry
Old 01-31-2013, 10:34 AM
essyou35
You can get 3s LIFE from Hobby king. Personally I would use the stock LIFEs that kingtech sells. I have one and it works great no problems at all with it. I can fly 6 times without a charge.
Old 01-31-2013, 02:53 PM
FenderBean
FenderBean's Avatar
Agreed the lowest weight 3200 pack I have seen is the stock one
ORIGINAL: essyou35
Old 04-02-2013, 10:32 AM
savasn
Barry, I am using a 2cell, 4400 Mamp, 7.4 V pack
is this ok for the ECU
Old 04-02-2013, 12:00 PM
marquisvns
marquisvns's Avatar
For E model ok, not for F or G.
Old 04-03-2013, 12:16 AM
savasn
Thanks for reply Barry
Why don't u suggest this batt, as manual says its ok?
what batt then do u suggest?
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
