K80G No External Glow Plug - How to Mount
My K80G has no external glow plug or access that I can see, my question is regarding mounting. The manual states:
David
"Place thebracket around the turbine, with the glow plug situated within the slot of the smallerbracket piece. This will help stabilize the engine along the thrust axis. The glow plugmust be in the vertical position, when mounted in your model (+/- 75° of enginerotation, from the glow plug at top dead center, is the allowable deviation)"
Do I still need to be concerned about the rotation of the turbine or can I just place the label at vertical and be done with it.Thanks,
David
