K70 not starting
K70 not starting
I have a Kingtech K70 which I cannot get to start, it was running fine until I crashed the model it was in so not surprised I’m having issues!
no visible damage but will not get past stage 1, the starter turns over well, glow is on, pump is pumping but no fuel travels up the line, I have tried priming with the line disconnected and all ok, when I test the fuel valve I hear the click but I put a piece of tubing on and it is very hard to blow down, air gets through but very little.
Should it be easy to blow down the tube when the valve is open? Any way to fix a stuck valve?
joe
joe
